Old 07-29-2018, 09:34 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Unless you are installing your amp in stock location, you probably want to fish new wires to the door anyways. Run 12-10AWG
Sent from my SM-G930W8 using Tapatalk
Old 07-29-2018, 10:30 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I am hoping to install the amp behind the head unit or somewhere close to it, under the dash. I would do a short run of heavier wire from the amp to the stock speaker wire harness where it would tie in to the stock wiring. Although I've done all my earlier installs, I'm actually considering paying to have this one done. My neighbour wants me to do a paint correction and sealant on his '14 Wrangler as well as refinish his door sills as the paint is worn off. What he pays me will offset the cost of the stereo installation.
Thanks for the input. 12 gauge would certainly be more than adequate, I expect. I'll consult with the stereo install guy too.
DIY keyless entry Viper 211HV w/ pics tmontague DIY / Maintenance / Service 24 07-06-2025 08:13 AM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
2009 4dr. LB Speaker Wiring Question AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 4 05-09-2010 09:48 PM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
Power wire gauge vs stereo wattage goku87 In Car Entertainment + Electronics (audio / video / alarm) 1 02-24-2009 02:16 PM
