Old 07-29-2018, 11:01 PM   #1
tmontague
tmontague's Avatar
You can simply pull the fuse but obviously the lights will stay on. Pull the connector, clean the contacts and then throw in some dielectric grease. If the problem come back than you'll need a new hub for the sensor and/or wire
Old 07-29-2018, 11:19 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks! I tried resetting the DTC with the jumper in, turning the ignition on and pressing the brake pedal 8 times within 5 seconds as per service manual directions. Didn't work. I'll remove the connectors again and add some dielectric grease. I'd still like to know what the blinking sequence means though.
Random Animated GIFs Thread kimona Off-topic / Other Cars / Everything else Discussions 394 12-01-2024 06:00 PM
Dark's Awesome 3rd Gen Build Thread/ His General Yaris Thread. DarkShadowFox Third Gen Yaris General Discussion 105 02-21-2019 03:56 PM
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 07:11 PM
Import Alliance Thread in the General Section tomato Off-topic / Other Cars / Everything else Discussions 9 07-12-2010 11:15 PM
