Old 08-05-2018, 10:38 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by dogsridewith View Post
Are these mostly replaced due to seals leaking? Any impeller seizures...which would probably make the serpentine belt squeal. (And wasn't there a recent post here somewhere about the impeller coming loose on the shaft?)
my first one had a bearing failure
Sent from my SM-G930W8 using Tapatalk
Old 08-06-2018, 09:17 AM   #2
dogsridewith
Drives: 2007 2-door hatchback
Toyota Yaris water pump bearing failure Chevrolet
Were you able to hear it and keep driving long enough to fix it before it started to leak or cook the serpentine belt or something?
(I was thanking Chevy 350V8 for original 71 waterpump and alternator that made bearing noise while still working perfectly.)
Old 08-06-2018, 11:11 AM   #3
IllusionX
It never leaked I don't think. I had it quickly replaced before it was out of warranty. I was about 4000km shy of running out :)
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
