#1 | |
As for smelling water, even though you didn't see water, some no doubt entered the cabin through the floor and saturated some of the carpet foam. As for your delayed starting, then runs fine situation, I've no idea.
#2 | |
![]() Drives: 2002 1.4 Diesel Join Date: Aug 2018
By the way about the starter, we asked an electrician and he said that the starter doesn't "turn over" (don't know if that's a correct term in english) and that causes the delay before starting |
![]() ![]() ![]() Drives: 2016 Yaris 3 Dr Super White Join Date: Mar 2016
Even though the carpet and padding is dry, it could be moldy. I would take carpet and padding out. You probably could shampoo carpet but I would replace the padding. As far as the starting problem goes, it could be a starter solenoid. Something to possibly look at. Perhaps the connections are corroded?
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
If the car smells like old rain water then water did get into the car even if you can't see it. Pull up the carpet in a few places and see if the insulation under the carpet is damp. Some cars have floorboards that are sloped to the back so water will collect in the rear foot-wells regardless of how it got in. Also check the spare tire area, and the rear storage spaces around the tire arches.
The problem with water damaged cars is that they can seem normal but can suffer from odd electrical problems. I'd check all the connections, ground points, and fuses of the starting system for any trapped water or signs of corrosion. Did your mechanic try to jump the starter manually? That can narrow things down to a bad starter/solenoid or the rest of the starting system. |
| Tags |
| car, flooded, start |
| Super weird Yaris 2003 A/C problem | zoharby | DIY / Maintenance / Service | 13 | 06-22-2017 11:14 AM |
| Extra protection stuff? | dimsum69 | New YARIS Purchase Forum | 9 | 09-19-2010 09:30 AM |
| Razo Stuff? | mastaofdisasta | Cosmetic Modifications (Exterior/Interior) | 6 | 11-06-2008 12:10 AM |
| Wheels and stuff, yeah stuff. | Yar | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-22-2007 09:10 PM |
| A/C smelling weird? | Yaris_PR | General Yaris / Vitz Discussion | 11 | 08-04-2006 08:26 AM |
