Old 09-03-2018, 08:49 PM   #1
Tedtalker
Drives: 2007 Yaris Sedan
The total capacity if the U340 AT is 5.68 quarts, but when you pull the drain plug only a bit over 2 quarts will drain. Pulling the AT cooling hoses and draining them and the AT cooler portion of the radiator drains about another quart. The remainder stays in the valve body and the torque converter.
I just performed a drain and fill with the Yaris jacked up on the drivers side only. a little over 3 quarts came out of the drain hole. Noticed when I let the jack down it quit draining. I jacked it right back up on drivers side and fluid started draining again. That's a tip from me to others here who will drain and fill. Over 3 quarts came out of mine. Yes indeedy!
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Old 09-04-2018, 06:45 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That's a great tip. Coming up on a drain and fill soon, so will give that a try. Thanks.
Old 09-09-2018, 10:05 PM   #3
Tedtalker
I also noticed an increase in MPG. I should have done it sooner! I used Valvolene Maxlife synthetic Automatic Transmission Oil from Wal-Mart. Toyota WS compatible. Tranny is silky smooth.
Old 09-15-2018, 03:14 PM   #4
barongan
Drives: m5
interesting thread, I have the same question
barongan is offline   Reply With Quote
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 08:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 05:01 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
