Old 09-04-2018, 06:45 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Tedtalker View Post
I just performed a drain and fill with the Yaris jacked up on the drivers side only. a little over 3 quarts came out of the drain hole. Noticed when I let the jack down it quit draining. I jacked it right back up on drivers side and fluid started draining again. That's a tip from me to others here who will drain and fill. Over 3 quarts came out of mine. Yes indeedy!
That's a great tip. Coming up on a drain and fill soon, so will give that a try. Thanks.
Old 09-09-2018, 10:05 PM   #2
Tedtalker
Drives: 2007 Yaris Sedan
I also noticed an increase in MPG. I should have done it sooner! I used Valvolene Maxlife synthetic Automatic Transmission Oil from Wal-Mart. Toyota WS compatible. Tranny is silky smooth.
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Old 09-15-2018, 03:14 PM   #3
barongan
Drives: m5
interesting thread, I have the same question
barongan is offline   Reply With Quote
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 08:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 06:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 05:01 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
