Old 09-17-2018, 01:13 PM   #1
flipside
Drives: 09 toyota Vitz
Engine swap
I know it’s been brought up or had some kind of discussions about this topic but I was wondering what type of an engine can our Yaris take without doing a lot of modifications on the engine mount or doing too much of modifications. Looking into an engine that can swap right away. I have a 2009 yaris Model S. Looking into a 2ZZ or 2ZR motor. Which in the two is better and easier for the swap. Or how about other bigger engine
flipside is offline   Reply With Quote
Old 09-17-2018, 01:32 PM   #2
saudi_boi
Drives: Red, 2015, 4 door sedan.
I'm new to this forum, how do I post new threads?
Hello from Saudi Arabia.
saudi_boi is offline   Reply With Quote
Old 09-17-2018, 06:20 PM   #3
Runethecursed
Drives: 2009 Yaris S
there's a posting requirement, join some topics and eventually youll be able to post your own
Runethecursed is offline   Reply With Quote
Old 09-17-2018, 03:03 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
A number of folks here have done the 2ZR swap. One did it in his driveway over a weekend (that thread was two threads down from yours in this very section). From my reading, it appears to be the easiest. It mates right up to the factory Yaris transmission. It's the swap I'd like to eventually do to my car.
Here are a couple 2ZR swap threads for you to check out.
http://www.yarisworld.com/forums/showthread.php?t=57875
http://www.yarisworld.com/forums/showthread.php?t=56523
http://www.yarisworld.com/forums/showthread.php?t=56233
As a cherry on top, here's a link to a thread about 2ZR aftermarket resources.
http://www.yarisworld.com/forums/showthread.php?t=57929
On Instagram
On Wheelwell
Old 09-17-2018, 05:19 PM   #5
flipside
That’s awesome. Thank you.
I’m in a process of looking and ready to purchase bigger motor. I wanna make sure I don’t get caught up with something that is impossible.
Old 09-18-2018, 05:27 PM   #6
atomic_hoji
Drives: 2018 Yaris SE 5MT
As noted, 2ZR swaps in pretty elegantly - all those threads are good reads too.
For the 2ZZ, it has been done as well, but from a quick re-read did require some more fabrication, and the OP was using a different base vehicle (i.e. not a 1NZ): http://www.yarisworld.com/forums/showthread.php?t=53132 There's also this thread: http://www.yarisworld.com/forums/showthread.php?t=13244, but is a lot of discussion, and not documenting the build.
I did a 2ZR in my 3rd gen. and other than some teething issues (which are mostly sorted now) and an annoying exhaust, it's peppy and makes for a fun little drive.
-- Adam
atomic_hoji is offline   Reply With Quote
2003 Yaris 1.3 engine swap help Jedi4690 DIY / Maintenance / Service 0 03-27-2018 03:08 PM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 01:01 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
