![]() Drives: 09 toyota Vitz Join Date: Jul 2016
Engine swap
I know it’s been brought up or had some kind of discussions about this topic but I was wondering what type of an engine can our Yaris take without doing a lot of modifications on the engine mount or doing too much of modifications. Looking into an engine that can swap right away. I have a 2009 yaris Model S. Looking into a 2ZZ or 2ZR motor. Which in the two is better and easier for the swap. Or how about other bigger engine
![]() Drives: Red, 2015, 4 door sedan. Join Date: Sep 2018
I'm new to this forum, how do I post new threads?
Hello from Saudi Arabia. |
#3 | |
Here are a couple 2ZR swap threads for you to check out. http://www.yarisworld.com/forums/showthread.php?t=57875 http://www.yarisworld.com/forums/showthread.php?t=56523 http://www.yarisworld.com/forums/showthread.php?t=56233 As a cherry on top, here's a link to a thread about 2ZR aftermarket resources. http://www.yarisworld.com/forums/showthread.php?t=57929 |
#4 | |
That’s awesome. Thank you.
I’m in a process of looking and ready to purchase bigger motor. I wanna make sure I don’t get caught up with something that is impossible. Quote:
there's a posting requirement, join some topics and eventually youll be able to post your own
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
As noted, 2ZR swaps in pretty elegantly - all those threads are good reads too.
For the 2ZZ, it has been done as well, but from a quick re-read did require some more fabrication, and the OP was using a different base vehicle (i.e. not a 1NZ): http://www.yarisworld.com/forums/showthread.php?t=53132 There's also this thread: http://www.yarisworld.com/forums/showthread.php?t=13244, but is a lot of discussion, and not documenting the build. I did a 2ZR in my 3rd gen. and other than some teething issues (which are mostly sorted now) and an annoying exhaust, it's peppy and makes for a fun little drive. ![]() -- Adam |
| 2003 Yaris 1.3 engine swap help | Jedi4690 | DIY / Maintenance / Service | 0 | 03-27-2018 03:08 PM |
| Yaris verso engine swap | Decieved | Performance Modifications | 3 | 06-10-2015 08:51 PM |
| Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
