Old 09-18-2018, 08:24 PM   #1
thetoyotaman
Drives: 2009 Yaris
All my research showed conflicting info on this so I ended up picking up a new head unit with install kit/wiring from sonic electronics. Ordered the backup camera from ebay. Any tips on mounting a universal back up camera?
thetoyotaman is offline   Reply With Quote
Old 09-22-2018, 04:44 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Unless it's a license plate one, you may have to drill a hole or two. I know that aliexpress sells manufacturer specific ones that fit in a license place light fixture and the camera is moulded into it for a much more finished look.
For example:
https://www.aliexpress.com/item/BigB...ceBeautifyAB=0
I wouldn't count on it being ultra high resolution. And, I think I would go for a hardwired one, not the transmitter/receiver type. Though that may require running more wiring. There are many choices. I just used search terms, "2009 Toyota Yaris Sedan Backup Camera".
Maestro RR Compatible? Sdelliott In Car Entertainment + Electronics (audio / video / alarm) 2 07-15-2017 11:29 AM
