Old 09-19-2018, 10:40 PM   #1
rcvmini
Drives: 2009 Yaris HB
Are you trying to use the key to start the engine or just use the fob to open the door? for for locks you can program yourself. Key to turn the engine on you need to program the transponder. I did one for my 09 hatchback a few years ago.
Check if your key has a dot or "G" you can then buy a blank and program the fob. you can use your current non remote key with the fob or you can take the small chip in the your non fob key and put it in the new FOB key and get it cut and it should work.
rcvmini is offline   Reply With Quote
2006 Yaris RS keyless entry details TheBeerglar DIY / Maintenance / Service 8 11-26-2014 11:21 AM
Found this 2014 Mitsubishi Mirage ES yesterday Hershey Off-topic / Other Cars / Everything else Discussions 97 01-30-2014 11:30 AM
Yaris Key fob wont lock my doors! Treeny DIY / Maintenance / Service 3 03-29-2012 07:27 AM
