An immobilizer harness should work no problem but the best bet is to pull the immobilizer pins front the connector that goes into the ecu just in case so this way the ecu has no chance that any signal for an immobilizer could be read
Ah, sounds like excellent advice. Whenever I get my harness and associated wiring diagram, I will endeavour to find those spots and see if there are any pins occupying them. If so, I will remove them. Thank you. I'd really still like to find out the differences - if any - between the auto engine harnesses.
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
