Old 09-28-2018, 07:32 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by ern-diz View Post
And ^that^ is the problem I would assume with these units.
Some stock radios are closer to 5 watts RMS so if the Chinese units get 14-17, it's an improvement, but marginally.
For my money, if I'm going for sound quality, I'm spending a bit more and going with something that pushes more RMS power per channel to get the most out of my speakers.
I went with a Pioneer and sometimes I think I should switch it out for a higher level Kenwood model.
I think you are right. I meant to say that the stock would have 14 - 17ish watts peak.
Although these units sound 'acceptable' (subjective, I know) out of the box, it really is amazing what a digital processing app such as PowerAmp can do. My systems are exceptionally clear, balanced but I do quite a bit of tweaking and I have a 4-channel amp, sub and extra tweeters. Neither a stock unit or one of these head units is going to have enough juice, as you say, to power an aftermarket speaker to the point that it produces a well-rounded, clean sound.
Old 09-28-2018, 07:51 PM   #2
miiser
miiser's Avatar
Drives: yaris 2009
ASAP information+opinions for Android Headunit.
Well sure, for an all around clear sound you need more things than just a HU. But is it the difference between the Chinese and brands, big? Or just marginal?
Ps: I will try the poweramp app you mentioned for sure, if I end up buying it
miiser is offline   Reply With Quote
Need opinions on these wheels ASAP! PumpkinSteve Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-16-2011 02:26 PM
Need some new headunit opinions pvt_melfi13b In Car Entertainment + Electronics (audio / video / alarm) 10 06-28-2010 06:54 AM
