![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
So I was able to get the drum off.
The drum was spinning freely so I assumed there was no issue with the pads dragging or getting stuck on it so I didn't mess with the star screw adjuster. I kept hitting the brake drum on the front face of it near all the bolts while spinning it around. Eventually I shocked it enough and was able to pull it off. As for tightening the slug I was able to do it by bringing my wheel up close and under the brake and using another tool wedged in the wheel spokes add the hub to stop it from turning while I tightened down a nut to pull the slug into the hole. I'm just glad that Toyota didn't design the thing so it is impossible to get the slugs out without doing a whoooole bunch of other work. There was enough space behind the plate to wiggle the slugs in and out so that was great. |
#2 | |
Another quick school autoshop story: A couple of kids were experiencing trouble getting the studs out past the backing plate of a 1/2 ton truck. One of them grabbed the torches and cut a little 'window' in the backing plate to take the stud out. Inadvertently, he cut out the shoe retaining pin slot. That car got bolted back up without any ebrake parts and a backing plate had to be ordered. While things like this are unfortunate, can be costly, and happen because of a low teacher-to-student ratio, these are learnings that are firmly entrenched, generally not having to be experienced a second time. Congrats on the getting the job done!
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-30-2018 at 07:50 AM. |
| Stripped E10 Torx Bolts trying to Remove Seats | IMAMEX | DIY / Maintenance / Service | 5 | 11-08-2016 08:28 AM |
| Rear Drum to Disc Brake Conversion | Mark-UPI | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-12-2015 11:26 PM |
| How to remove rear speaker panel on a Liftback? | W.A.S.P | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 11-25-2006 01:45 AM |
