Tom is correct about leaving the trans in the car while swapping the engine. I removed my whole trans w/ the motor because I was replacing the clutch and flywheel.
That said putting the 2zr back into the engine bay and lining up the main shaft to the engine would be a huge pita compared to easily doing it off the car. Imho I actually think it is quicker to pull them both together, reassemble w/ the 2zr and slide them both back in together. When the front of the car is off there is a ton of room to remove the trans and engine. Ultimately you will have to decide what works best for you but the 2zr block is a direct bolt on including the starter
#2 | |
Let's say that I do take both out and put both back in together, will the axles slide into place without having to break the ball joints and pull the struts out?
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
