Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
That blue wire coming out of you xD harness shift control plug should be cut about 8" from the plug and grounded to the transmission case. If you would have scrolled down further on Brushfohires post you would see that.
The hose that's missing is still there....its just hanging down by the throttle body. It must have accidentally been pulled off the port. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 10:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 10:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
