Old 10-29-2018, 06:27 AM   #1
tmontague
tmontague's Avatar
From what u remember that appears to be the correct spots. However, I'd need to go through the threads to confirm
Old 10-29-2018, 09:32 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Yeah, I think it's right. I think I did what Tom said to do as per brushforhire's thread. Just wanted to be sure. Thanks Trevor.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
