Old 11-07-2018, 12:08 PM   #1
tmontague
tmontague's Avatar
What you were looking at in the diagram wasnt the intake manifold, it was the exhaust manifold.
It's on the back of the block under the exhaust manifold.
FWIW you only end up removing an extra 100mls or so when you use the block drain valve compared 5o the radiator pet cock
Old 11-07-2018, 09:25 PM   #2
SirDigby
Drives: 2007 yaris 3 door
this is true. it's not really a "drain." more of a "bleeder" for when you are filling the system. air can become trapped it that area and it's good practice to crack it open when filling... (of course close it when coolant flows out)
also, what does "FWIW" mean?
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 09:33 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
