![]() Drives: 2010 Yaris Seden Join Date: Aug 2018
Engine Block Coolant Drain Cock Location
Sorry for the stupid question. But where is the Engine Block Coolant Drain Cock located on a 2010 1nz-fe, found a "diagram" online that showed it just about the intake manifold, but the bolts or plugs around there are the intake manifold bolts.
What you were looking at in the diagram wasnt the intake manifold, it was the exhaust manifold.
It's on the back of the block under the exhaust manifold. FWIW you only end up removing an extra 100mls or so when you use the block drain valve compared 5o the radiator pet cock
#3 | |
also, what does "FWIW" mean? |
"For what its worth"
There is no way I'm reaching near that exhaust manifold while the car is running to bleed the coolant The 1nz bleeds very very well by itself within the first week of driving it. Keep the overflow reservoir topped up and your good to go
Hey that belongs in this thread:
http://www.yarisworld.com/forums/showthread.php?t=61233 Does anyone get the reference? |
| DIY: Engine Grille Block | BailOut | DIY / Maintenance / Service | 39 | 11-11-2017 09:33 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| engine block heater | linny | DIY / Maintenance / Service | 6 | 01-19-2012 11:22 AM |
| Engine Coolant Temperature | djino | General Yaris / Vitz Discussion | 18 | 07-16-2007 12:26 AM |
