Old 11-10-2018, 07:40 AM   #1
eeeeeh
Drives: Yaris YR 2013
Smile Finally got it done!!
Okay, finally done the wiring. End product looks like this.
1. Remove the front map reading light assembly. Solder a connector to these two locations. Of course use your multimeter or a simple lightbulb to test polarity.
2. Run wire from the assembly recess through to windshield, then under the roof lining and across to each A-pillar. Going around the airbag (do not obstruct) and through to under rubber seal. Run along and above the seal through to B-pillar.
3. Rear door rubber seal, you'd need to slit two holes to fit the flexible LED strip light through.
Something like this should suffice (the one I bought earlier no longer exist).
https://www.ebay.com.au/itm/Waterpro...YAAOSweNZa8V~u
Now my rear lights fade out just like the map light. (animated GIF)
https://imgur.com/jHOHeAA/
Since the hard part of wiring is done, I can now easily do the footwell light.
eeeeeh is offline   Reply With Quote
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 09:46 AM
Help: Water/Moisture Entered Fog Light Assembly bigsky2 DIY / Maintenance / Service 10 12-19-2006 12:10 AM
