Old 11-14-2018, 03:56 PM   #1
praivo
Drives: 2000 SCP10, 2001 NCP13
when i change gears on 50-100% throttle it jerks just when i release the clutch after shifting.
Sounds like you're getting back on the throttle too late.
t has a bad exhaust, so can this be a problem coming from the two o2 sensors reading wrong values causing rich or lean fuel mixture?
Yes, most likely it would make it run rich because it would think it's running lean when it's not (due to the oxygen in the air drawn into the exhaust through the hole).
The yellow engine light also comes on after driving for about 20-30 minutes after resetting the ECU.
Can't tell much without knowing the code that activated it.
praivo is offline   Reply With Quote
Old 11-15-2018, 03:09 PM   #2
HaavardPYA
Drives: 2001 Yaris Verso 1,3
Thanks for the answer. I don`t think so, because it happens when i doing rapid shifts. Same thing happens when I´m driving on low revs and put the pedal down too fast. Maybe running rich then, as you said? :)
HaavardPYA is offline   Reply With Quote
Old 11-16-2018, 02:23 PM   #3
Rednaz
Drives: 2006 Yaris 1300
I have the same problem with my 2NZ but I suspect it may be my fuel pump failing? So I'm doing diagnostics and pump replacement next soon.
Rednaz is offline   Reply With Quote
Old 11-16-2018, 03:44 PM   #4
praivo
More like running lean and/or not picking up throttle position changes quickly enough. Usually either a REALLY dirty MAF sensor or a bad upstream O2 sensor. On a Yaris it's more than likely to be the MAF sensor. I had to scrape the dirt off mine with a needle to really get it clean and working again.
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
2013 yaris 2nz yaser DIY / Maintenance / Service 0 12-14-2015 07:47 AM
2nz pistons in 1nz salmanghiyas Performance Modifications 1 11-15-2014 01:30 PM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Turbo for 2NZ.... Centurion2200 Forced Induction Forum 9 08-25-2007 06:14 AM
