Old 11-14-2018, 08:38 PM   #1
SirDigby
Drives: 2007 yaris 3 door
have you performed the throttle learn procedure? have you tried taking your foot off the accelerator before pushing the clutch pedal? i've only had this happen a few times when i first purchased my car, but i found these things really solved the issue and it has not happened in years. in the case of the a/c, it's probably the extra resistance on the belt bogging the belt enough that the rpm drop is assisted...
Old 11-15-2018, 08:14 AM   #2
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
I am used to it now and release the throttle and then wait a split second before disengaging the clutch, but I still don't like it even after owning the car for more than 10 years.
What throttle learning procedure do you mean? I've had the battery unplugged dozens of times and have experienced the ecu learning process.
Leegamer is offline   Reply With Quote
Old 12-10-2018, 07:24 PM   #3
Tinkerman
Drives: Yaris 5 speed
To reduce Rev hang, I haven't done this on Yaris but did it in BMW.
Find the intake hose that feeds the ICV then reduce the size to it and you will drop rev like a rock.
Tinkerman is offline   Reply With Quote
Hang Time: Exploiting ECU Fuel Maps for Fuel Efficiency BailOut Fuel Economy Forum 20 11-13-2013 08:11 AM
Rev limiter Jabro DIY / Maintenance / Service 5 12-02-2012 01:52 PM
FS: Vitz Hyper Rev magazine mrbond Items for Sale by private party 10 02-08-2010 03:28 PM
rev limiter mastaofdisasta Performance Modifications 2 11-24-2008 03:10 PM
Hyper Rev: Vol# 108 Vitz (No. 3) **IN STOCK & READY TO SHIP** KamiSpeed Sponsors Classifieds Area 1 03-03-2007 01:50 PM
