![]() Drives: 2001 Yaris Verso 1,3 Join Date: Nov 2018
Thanks for the answer. I don`t think so, because it happens when i doing rapid shifts. Same thing happens when I´m driving on low revs and put the pedal down too fast. Maybe running rich then, as you said? :)
![]() Drives: 2006 Yaris 1300 Join Date: Jan 2014
I have the same problem with my 2NZ but I suspect it may be my fuel pump failing? So I'm doing diagnostics and pump replacement next soon.
![]() ![]() Drives: 2000 SCP10, 2001 NCP13 Join Date: Jul 2016
More like running lean and/or not picking up throttle position changes quickly enough. Usually either a REALLY dirty MAF sensor or a bad upstream O2 sensor. On a Yaris it's more than likely to be the MAF sensor. I had to scrape the dirt off mine with a needle to really get it clean and working again.
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 09:40 AM |
| 2013 yaris 2nz | yaser | DIY / Maintenance / Service | 0 | 12-14-2015 07:47 AM |
| 2nz pistons in 1nz | salmanghiyas | Performance Modifications | 1 | 11-15-2014 01:30 PM |
| 1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods | jtw11 | Performance Modifications | 8 | 09-03-2013 01:49 PM |
| Turbo for 2NZ.... | Centurion2200 | Forced Induction Forum | 9 | 08-25-2007 06:14 AM |
