Old 11-17-2018, 05:29 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by Hoodyjay View Post
I tried unplugging the DRL relay under the steering column yesterday, it's like -22 degrees Celsius where I am and my hands were frozen lol. I couldn't get it out. I was thinking if I do get them out I can just turn the headlight switch halfway where only my yellow parking lights will turn on?
They will. If you unplug the module, the OEM fog lights (if you have them) will also stop working.
The orange wire needs grounded to work (independently). The module keeps fogs working like OEM.
If you want to properly disable DRL, you need to cut the thick blue (iirc is light blue) from the module, then you can use the signal to power lights of your choice.
One day, one day I will pull the module out and take a picture of my modification. Hehe
What you can also do is wire up a relay, and turn on a set of lights on car start. You have many many options.
Also, not sure what the law says about DRL in Alberta, but Quebec SAAQ says they have to be stock location. Although no one gives a damn about it.
Old 11-17-2018, 09:22 PM   #2
Hoodyjay
Drives: 2007 Toyota Yaris Sedan BASE
All those wire and relay talk got me confused af lol. I think I will just try to pull the relay again when it's slightly warmer. If I do get in shit, that relay is already hard enough to get out, I can't imagine putting it back in. I might just run with my headlights turned on fully even in the day. I imagine that it would lower its lifespan but oh well.
Hoodyjay is offline   Reply With Quote
Additional roof led light Eduardo_mty Cosmetic Modifications (Exterior/Interior) 7 10-06-2018 11:59 PM
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
Led side blinker to dome light vitz1000 DIY / Maintenance / Service 0 05-26-2015 10:52 AM
Upper third brake light led mod for the yaris sedan YarisSedan DIY / Maintenance / Service 2 05-22-2013 12:52 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
