Old 11-18-2018, 02:30 PM   #7
tmontague
tmontague's Avatar
If it is worse when load is transferred to the rear and you have a worn/crumbling bushing then that is the likely culprit.
Those bushings are the only thing holding all of the rear of the suspension to the car (with the exception of the rear shocks which are not supportive). If a bushing is worn this can cause vibration/noise to resonate into the cabin such as the simple noise and vibration that comes from a tire/wheel turning on the road.
I'd inspect that bushing further.
My car makes all sorts of noises and pops ever since it started to become a track car. I always inspect underneath it and make sure everything is sound. As long as it all checks out then I let it go. Seems to work well this way.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
Request: Picture of the transmission end of passenger CV axle WildChild DIY / Maintenance / Service 2 06-16-2014 12:35 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
