#433 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Can’t thank you enough for the handsome gifts you’ve generously distributed to us. You’re kindness will be remembered every time the emblem strikes a conversation.
#434 | |
I haven't mounted my badge yet, but hope to soon. I'll post up a pic. I think a dedicated thread with pics of all our swapped cars with the badges would be cool. As a brief update, I'd had been having some exhaust issues. The Megan was banging on the spring pan under any driving conditions. I had it in the shop yesterday and tried some adjustments. I turned the midpipe (it's fixed with a clamp in the middle) and tightened the clamp and removed and reinstalled the rear spring bolts. Also replaced a few rubber hangers. It's still not where I want it. It's also hanging a bit low for my liking. On hard left turns and a bump, it will hit the plate. I'm really considering taking it to an exhaust shop and having them do it, including upping the resonator to muffler flange with 2.25" pipe. About a month ago, a rock flew off an oncoming car and cracked my windshield close to the passenger A-piller. It was about - 15C here yesterday and as I started driving to work - I took it to work to fix the exhaust - I heard this sound like a zipper and the crack shot right across the windshield, right to the driver's side. I've been romping on the car a bit more lately - running it up to close to redline from about 30 km/h up and, man, this thing pulls!!! Not that torque steer is a desireable attribute, but it's nice to know there's extra power there. I can see why an LSD would be great for additional traction and likely necessary with any additional performance upgrades. ![]()
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-23-2018 at 06:19 PM. |
#435 |
An LSD also helps huge in the snow - or at least a clutch type LSD does. I'm amazed at how well it chugs through the snow with winter tires while both front tires are spinning.
A stock height yaris with 4 winter tires and a clutch type LSD would be a snow machine. Just woukdjt make much sense to put that amount of money into a yaris for snow traction if you could just buy an awd for that amount. I echo Tom's sentiments, thanks a ton for buying us all the badges, it was a great idea and much appreciated
#436 | |
Yeah, I bet an LSD would be amazing. Just as a matter of interest, would the same LSD be used for both auto and manual transmission? On another note, I've been watching videos on the Yaris's that have been swapped with the 2ZZ engine. Now that would be a swap! That valve lift is something else. I bet the Yaris transmission would grenade if connected to one of those engines. I wonder if a 2zz and its mated transmission would be a crazy difficult install.
#437 | ||
![]() ![]() ![]() Drives: 2018 Yaris SE 5MT Join Date: Aug 2017
Hhhmmm... LSD + winter tires = snow machine, you say... re: exhaust - it seems to be the way of the world, lol. Functionally, it works just fine, but the principle of clunkage and banging is just a nuisance.. I hear ya. I'm sure the professionals at a decent exhaust shop can get you sorted. Overall the car is looking (and sounding) great, man.Take care! -- Adam |
#438 |
Data doesn't lie
You can’t use a clutch type lsd in an automatic due to he fluid type restriction. You could install one of those wavetrac units though, but I’m not sure it’s worth the effort
#439 |
Ah, interesting. Thanks! Yeah, it sounds like it would be crazy expensive. I'm more than happy with the performance as it stands. I had it out tonight - the roads are clear and dry - and I did a few pulls from about 30 km/h up. Pulls, pulls, pulls. I did one 0 - 60 run but couldn't get my dang Torque to record my time. On the way back from the store there's a long hill on the highway. I sailed up that at 140 and the 2zr wasn't even breaking a sweat. Exhaust sounds pertty good inside with very minimal droning - nothing that a couple more clicks of the volume knob won't fix. At cruise, around 110 km/h and about 2800 rpm, it's very acceptable.
#440 | |
I haven't shipped your or Trevor's badge yet as I haven't time to seek out alternative shipping. But, it should be soon though.
#441 | |
2ZR swap. DO IT! Ask how!
#442 |
Haha, no you're not. I think I'll wait until spring, when the car comes out of storage, to get the window replaced.
#443 |
Badge
Looks as though the badge is going to require some modifications to fit on my car. The original TS grille seems to be more of a 'square' honeycomb and mine is more of a vertically elongated honeycomb. So, I'll be thinking about ways to adapt it to fit. A little disappointing, but definitely solvable. I'm wondering if a really strong RTV sealant would be adequate. I thought I might buy a knockoff TS grille but the only honeycomb style grilles on eBay appear to be the same as mine. Sorry, gentlemen, I thought these would be a direct fit, snap on item - at least for Sam and me (hatchbacks). If anyone has any suggestions about how to afix the badge, I'm all ears. Thanks.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-26-2018 at 06:50 PM. |
#444 |
How about knocking enough clip off to allow it to sit flat on grill. Epoxy a nylon bolt onto the back of badge. Tighten into grill with nylon nut.
#445 | |
Here are a couple pics. Sorry about the quality. Crap camera and bad lighting. ![]() ![]() ![]() Here's a better one taken outside.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-02-2018 at 08:36 PM. |
#446 |
Data doesn't lie
Awesome!
#447 | |
#448 | |
Looks like your badge arrived. I look forward to seeing it on your car when you get the opportunity to install it.
#449 |
Picked up my sway bar and A/C manifold gauge kit and the fittings needed to attach to the R134 can. Required an R134 can tap, flare to male pipe half union and pipe coupling.
I nearly gave myself a hernia lifting the vacuum pump out of the box. Man, that's a solid pump! ![]() Holding 30" of vacuum after 90 minutes. I'm confident that the system is leak free. Will put a 45 minute vacuum on the system tomorrow, then fill with refrigerant ~15 - 17 oz, or about 1 and slightly less than 1/2 cans. EDIT: looks more like 13 - 14 oz of R134 All this, just in time for winter. At least the system will remain uncontaminated. I didn't want to leave any air/moisture in the system.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-19-2018 at 10:51 PM. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
