Old 11-23-2018, 08:50 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
You can’t use a clutch type lsd in an automatic due to he fluid type restriction. You could install one of those wavetrac units though, but I’m not sure it’s worth the effort
ArmstrongRacing is offline   Reply With Quote
Old 11-23-2018, 10:26 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Ah, interesting. Thanks! Yeah, it sounds like it would be crazy expensive. I'm more than happy with the performance as it stands. I had it out tonight - the roads are clear and dry - and I did a few pulls from about 30 km/h up. Pulls, pulls, pulls. I did one 0 - 60 run but couldn't get my dang Torque to record my time. On the way back from the store there's a long hill on the highway. I sailed up that at 140 and the 2zr wasn't even breaking a sweat. Exhaust sounds pertty good inside with very minimal droning - nothing that a couple more clicks of the volume knob won't fix. At cruise, around 110 km/h and about 2800 rpm, it's very acceptable.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
