Badge
Looks as though the badge is going to require some modifications to fit on my car. The original TS grille seems to be more of a 'square' honeycomb and mine is more of a vertically elongated honeycomb. So, I'll be thinking about ways to adapt it to fit. A little disappointing, but definitely solvable. I'm wondering if a really strong RTV sealant would be adequate. I thought I might buy a knockoff TS grille but the only honeycomb style grilles on eBay appear to be the same as mine. Sorry, gentlemen, I thought these would be a direct fit, snap on item - at least for Sam and me (hatchbacks). If anyone has any suggestions about how to afix the badge, I'm all ears. Thanks.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-26-2018 at 06:50 PM. |
#2 | |
2ZR swap. DO IT! Ask how!
#3 | |
Looks like your badge arrived. I look forward to seeing it on your car when you get the opportunity to install it.
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
