Old 12-05-2018, 01:46 PM   #1
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Originally Posted by petros37 View Post
Hi
I have yaris 2013 1nr-fe 1.33 engine europe specs and installed the cruise stalk .
The problem is the indicator at the instrument cluster doesn't lit .Otherwise the cruise control works just fine .
Is it possible to fix this problem ?
Which instrument do you have.
If its the basic one without RPM meter it probably also dont have the cruise light.
Then you can switch it to one of these which should have cruise lights, my car has it.
https://www.ebay.de/itm/Toyota-Yaris...p809:rk:2:pf:0
https://www.ebay.de/itm/Toyota-Yaris...UTE:rk:36:pf:0
https://www.ebay.de/itm/Tacho-Kombii...MAAOSwyWlbpqhd
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 12-05-2018, 03:53 PM   #2
petros37
Drives: Yaris 1.3 europe
I have the one with the RPM meter and i am sure that it has the cruise
light because i can see it with a flashlight but for some reason the light don't lit .
Maybe it's something that need to be unlocked through toyota diagnostic
computer or something else that i don't know .
petros37 is offline   Reply With Quote
cruise control. 2012
