![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Clinkling,tinkling metallic sound.
It only makes this noise when in the higher revs just before you would gear up.Lets say I have it in third going up a hill and stay in the higher end of third I hear this tinkling sound,could be comming from passenger side of engine?.As soon as I change gear the noise dissapears because of lower rpm.Just curious if any others have heard same noise?
From a bit of research this could be the timing chain? |
My best guess is that the heat shield around the exhaust manifold has rusted in one or several locations and is rattling. The easiest fix is just rip it off.
#3 | |
I do not think the sound is related to vibration.The higher rpm is not causing vibration/s
I will remove shield and see,but... |
Easy enough to check it. Just reach in over the valve cover and grab it. If it moves, then there is your answer. Chances are one or both of the attachment points near where the exhaust pipe meets the manifold are shot. I ripped mine out last year.
Have you heard what Iam describing only higher rpm?
If it is the shield which one.The one closer to the gas tank was resecured with self taping screws when I did Ebrake cable.You say manifold so it would be inside the engine compartment? |
#7 | |
Oh oh oh check your water pump/ water pump seal.
#9 | |
Solved!
Solved: weeyari and the barber were 100% correct.
huzzah!
Its actually still attached fairly good.Looks to be one of the 3 screws that has come undone.I may try to rescrew the one.
Tight fit and may need to remove black engine cover thing and cowling.Just glad the noise is cosmetic so to speak. |
#13 | |
My 2 bottom bolts have completely broken off, so if anything, I'm just going to remove the shield. My exhaust manifold had a hole where it meets the cat,so it might just be a new exhaust manifold at that point. Sent from my CLT-L04 using Tapatalk |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
heat shield - is it like an aluminum sheet covering the exhaust pipe and held by 3 bolts? i think my heat shield also moves and make a sound, it looks like it has a washer made of rubber???? there is slight play but you can hear it metal to metal hitting the bolts..
i think i need to replace the washers but i dont know the part number... can you pls tell me the part number of the washers used for this? Yaris 2016 Sedan |
#15 | |
Just take it off. It’s so much easier than messing around with it to keep it
#16 | |
rattle
Could it just be the engine showing its age? Its annoying whatever it is.I have heard identical sound on older beat up cars. |
There are six heat shields in total. The other 5 are all under the car. You'll have to get under there and check them all for corroded connection points. I've had to deal with 3 underbody shields over the past few years.
#18 | |
Currently looking around and came across this.He describes what I have pretty near spot on. https://www.rx8club.com/rx-8-discuss...-makes-218482/ I know these are rotary engines and they have a metallic sound but thats not what he is talking about.(I used to have a RX7 BTW) This post aswell.Heatshields. I will check it out tomorrow. https://itstillruns.com/car-problems...g-5522072.html |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 05:35 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| Raising the sound stage... | SAV912 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-30-2011 05:26 AM |
| Odd Metallic Sound From The Engine Bay | Kaotic Lazagna | DIY / Maintenance / Service | 5 | 08-29-2009 03:03 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 03:11 AM |
