Old 12-06-2018, 08:12 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Picked up my sway bar and A/C manifold gauge kit and the fittings needed to attach to the R134 can. Required an R134 can tap, flare to male pipe half union and pipe coupling.
I nearly gave myself a hernia lifting the vacuum pump out of the box. Man, that's a solid pump!
Holding 30" of vacuum after 90 minutes. I'm confident that the system is leak free. Will put a 45 minute vacuum on the system tomorrow, then fill with refrigerant ~15 - 17 oz, or about 1 and slightly less than 1/2 cans. EDIT: looks more like 13 - 14 oz of R134 All this, just in time for winter. At least the system will remain uncontaminated. I didn't want to leave any air/moisture in the system.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
