![]() ![]() Drives: Yaris 12 Join Date: Oct 2016
Sticky clutch pedal
Hello,
Started yesterday, the clutch pedal is sticking down there, really annoying. When I push down and release, it comes back half an inch and stop, then I have to remove pressure and it goes up suddenly. Do you think it's the clutch master cylinder? already bad after 50000 miles. |
#2 | |
Bleed clutch
I'd at least bleed the clutch first. (Read threads here on this.) For me and others here it brought up a too-low engagement point a bit...and we got some grit in the bleed fluid. I like to run the right front wheel up on a ramp first to put any bubble closer to the bleeder. (Low ramp...lots of ramps are too steep for the Yaris bumper. This vehicle tilting is not in the shop manual, and I've never seen anyone mention it anywhere.)
ok guys thanks.
Do you know where I could get a repair manual for 2012? it's like pass 2011 this car does not exist
| YARIS Clutch Pedal Noise | mik23 | DIY / Maintenance / Service | 3 | 04-27-2022 08:41 AM |
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Squeaky Clutch Pedal? | Kaotic Lazagna | DIY / Maintenance / Service | 43 | 05-29-2016 01:15 PM |
| Clutch pedal assembly interference with foot | Connoisseur_of_fine_cars | General Yaris / Vitz Discussion | 4 | 09-23-2011 10:57 AM |
