Old 12-12-2018, 03:05 AM   #1
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Originally Posted by NYC-SE View Post
I swapped out the LCA bolts last week. The drivers side bolt looked OK with only a slight amount of surface rust. The passengers side, aka the side that was making the clunking noise, was in considerably worse shape. I suspected there may be a problem when I loosened the bolt and a stream of rusty water came pouring out. Not drops, a solid STREAM. I should mention that it had not rained for a week prior and that the preceding two days had a temperature of 80F. As you can see from the photo there was a significant amount of corrosion around the shaft close to the bolt head. The result of exposure to three relatively mild winters. I'm glad I caught it when I did, I would hate to see what a few more years would have brought.
Prior to installing the new LCA bolts I covered them with a thick coating of a high quality calcium sulfonate marine grade grease. Hopefully that will help to ward off future damage. Nevertheless I plan to remove and inspect them on an annual basis.
It has been 10 days since I did this and I have not had any clunking noise in that time so I think I can confidently say this was the cause. I specifically waited before posting because I wanted to be certain. Previously I would have typically had several episodes of clunking within that time frame.
So it goes without saying that this is still an issue with 3rd gen cars, regardless of what Toyota will tell you. The TSB needs to be updated and the warranty needs to be extended for 3rd gen cars as it was for the 2nd gen.
FYI for those who suspect this may be an issue with their car: The only symptom I had was the clunking noise. The car rode, handled, steered, braked fine. Everything that you could see of the front suspension looked fine too. That's the problem, the LCA bolts are hidden. If you are in a heavy salt area and you are clunking you need to check the LCA bolts.
Hi i have a 3rd Gen Yaris 2014.. i have the same problem. can you provide me with the part number for the LCA bolts so i will also replace mine...
rayfloyd170 is offline   Reply With Quote
Old 12-12-2018, 08:03 AM   #2
I see you are in Saudi Arabia. I doubt very much that you have a corrosion issue with the LCA bolts. These were an issue in winter climates where salt and brine treatments are applied to the roads.
Sent from my EML-L09 using Tapatalk
Old 12-12-2018, 12:21 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
To answer your question the part number for the LCA bolt is 90119-14151. You would need 2. BUT... as WeeYari said being in Saudi Arabia there is no way that the LCA bolts are causing your problem unless your car was used and imported from a snow area.
Old 12-16-2018, 04:08 AM   #4
rayfloyd170
Thank you for your prompt response.
This is my situation, i intermittently hear the clunking sound on the driver side suspension whenever i slow down and pass some humps... but the clunking sound wont come when the car is stationary and when i try to bounce it ( it just wont happen)...
its just so weird, this sound came after i made an under-chassis wash (was preparing for annual motor vehicle inspection and need to present my car clean and free from dirt).
the car wash shop used a high pressure spray with something like ( kerosene or diesel mix) ... i thought that was the culprit.. maybe it removed some of the pre-applied grease to some parts including the LCA bolts...
i tried to spray those areas with lithium based grease to no avail...
maybe it time to have it checked by a mechanic... its 68K KM
Colour Collection 05 Reg (UK) brake noise JLx DIY / Maintenance / Service 0 07-14-2015 06:56 AM
metallic noise when accelerating poida DIY / Maintenance / Service 3 03-29-2015 12:20 AM
Yaris mk1 1.0 engine clunking noise Gpav6 Performance Modifications 1 08-13-2014 01:42 PM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
