#1 | |
Sent from my CLT-L04 using Tapatalk |
#2 | |
JDM Fan!
Drives: '06 Yaris Join Date: Sep 2018
Thanks for your suggestion. I think the wires are ok since I get power to all other bulbs. In fact I tried swapping positions and the high beams came on at the low beam position. My suspicion is that somehow there is insufficient power to turn on the HID ballast. I know they work because I have tested them with a portable battery charger and they light up well. I had a Rav4 where the factory wiring powered HID projectors I had retrofitted without a wiring harness. I drove that for 7 years no problem. I expected the same from my little Yaris
Regards, DeeBee |
#3 | |
H4 was designed with a common ground and 2 positive, but the Yaris has a common positive like mentioned above. Sent from my CLT-L04 using Tapatalk |
yes, the jdm factory HIDs are indeed designed to have both run at the same time when high beams are on. My high beams are regulated to flash duty only.
I have repeatedly blown the 10A fuse, and moved to 15A. If you want both beams on, I'm pretty sure there will be alot of blown fuses, after the wire kung fu that's needed for it to happen...or you wire the hi beam up like it were a fog light. I love the adjustment range of the HIDs and it can adapt to us roads well...that cut off is indeed there, but in the US where a vast majority of cars on the road are towering SUVs that blind the crap out of us...either they dont notice it, or if they do...SCREW EM. *the high beams will definitely blind the other side really badly. |
#5 | |
JDM Fan!
Thank you for this confirmation. I had hoped this would be the case on the occasional times I may need to use my high beams.
Regards, DeeBee |
#6 | |
JDM Fan!
I can confirm that when I select high beams, my low beams turn off ![]() I rewired my harness following the link shared by fredovvti but the result did not change ![]() I think the wiring maybe different up at the switch/fuse terminals ![]() I love the HID output but its frustrating on the country roads here where high beam would be nice to see further out at a depression.
Regards, DeeBee |
wish i can help you with that lo and high beam problem..i only have 1 theory that may or may not work. (wiring the H7 high beams as a fog light instead).
any other options and im scared there will be shorts or small fires lol. |
| FS: 2012 Yaris oem headlight projector retrofit | ucsmfu | Items for Sale by private party | 4 | 11-01-2016 10:28 PM |
| How can i get the OEM Headlight Stalk with FOG switch to work | murtaza.shahid | DIY / Maintenance / Service | 0 | 11-22-2014 06:30 AM |
| DIY - A EASY&FAST way to change headlight bulb | ALLBLACK | DIY / Maintenance / Service | 0 | 09-18-2010 01:40 AM |
| FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal | 03Z33 | Items for Sale by private party | 30 | 01-02-2009 06:55 PM |
| DIY - JDM RS style REPLICA tails | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-21-2008 02:56 PM |
