Old 12-14-2018, 04:05 PM   #1
enviri
enviri's Avatar
Drives: 2010 Yaris
yes, the jdm factory HIDs are indeed designed to have both run at the same time when high beams are on. My high beams are regulated to flash duty only.
I have repeatedly blown the 10A fuse, and moved to 15A.
If you want both beams on, I'm pretty sure there will be alot of blown fuses, after the wire kung fu that's needed for it to happen...or you wire the hi beam up like it were a fog light.
I love the adjustment range of the HIDs and it can adapt to us roads well...that cut off is indeed there, but in the US where a vast majority of cars on the road are towering SUVs that blind the crap out of us...either they dont notice it, or if they do...SCREW EM.
*the high beams will definitely blind the other side really badly.
Old 12-17-2018, 06:02 AM   #2
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Hi enviri,
Thank you for this confirmation. I had hoped this would be the case on the occasional times I may need to use my high beams.
Regards,
DeeBee
DeeBee is offline   Reply With Quote
Old 12-27-2018, 06:03 PM   #3
DeeBee
JDM Fan!
DeeBee's Avatar
Drives: '06 Yaris
Hi enviri,
I can confirm that when I select high beams, my low beams turn off
I rewired my harness following the link shared by fredovvti but the result did not change
I think the wiring maybe different up at the switch/fuse terminals
I love the HID output but its frustrating on the country roads here where high beam would be nice to see further out at a depression.
Regards,
DeeBee
Old 12-27-2018, 07:53 PM   #4
enviri
enviri's Avatar
Drives: 2010 Yaris
wish i can help you with that lo and high beam problem..i only have 1 theory that may or may not work. (wiring the H7 high beams as a fog light instead).
any other options and im scared there will be shorts or small fires lol.
FS: 2012 Yaris oem headlight projector retrofit ucsmfu Items for Sale by private party 4 11-01-2016 10:28 PM
How can i get the OEM Headlight Stalk with FOG switch to work murtaza.shahid DIY / Maintenance / Service 0 11-22-2014 06:30 AM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal 03Z33 Items for Sale by private party 30 01-02-2009 06:55 PM
DIY - JDM RS style REPLICA tails kurokoma-kun DIY / Maintenance / Service 0 10-21-2008 02:56 PM
