Old 12-14-2018, 04:07 PM   #1
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
get the TRD engine mounts, the stock ones are vibration prone. or make filled mounts with poly.
DarkShadowFox is offline   Reply With Quote
Old 12-17-2018, 08:15 AM   #2
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Do you have a part number for those?
Also did confirm vibration is happening only when the car is in drive and at a stop with AC on. Does not vibrate in neutral with my foot on the brake.
firebird1999us is offline   Reply With Quote
Old 12-17-2018, 10:08 AM   #3
tmontague
tmontague's Avatar
Poly filled mounts/stiffer will only make the vibration worse.
High idle that you have is completely normal. With more load on the car the vibration is also normal. The 1nz has a relatively low idle for a 4 banger so it will vibrate with high load on it at idle and then the idle will rise slightly and the vibration will go away. This will periodically fluctuate and happen.
Old 12-17-2018, 11:12 AM   #4
firebird1999us
Drives: 2003 Mach 1
I may have mispoke - the issues are independent. The idle doesn't fluctuate when the vibration happens. The idle remains the same. It's got to be the AC causing it. This is a new development since I swapped the alternator. I just used a Duralast alternator from autozone.
