The LCA bolts are not greased from the factory so you did not wash away any grease from them since there was none to begin with. However you may have washed grease away from some other components especially since you used kerosene. (why?) I would start with the front disc pads. Perhaps the grease on the back plate was washed away and they are rattling.
#2 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
BTW i went to toyota showroom and asked them about this and it is very funny they are not selling the LCA bolts... they said i need to look for it.. too bad.. i guess customer service here isnt up to the mark. |
#3 | |
FIXED MY PROBLEM
I went to a car mechanic and the he drove the car while i was instructing him on when i normally hear and to further explain him about the unusual clunking sound. He then checked the LCA bolts and bushing of the control arms and others... He sprayed lubricant (i think lithium based spray) to the bushing area where the bolts are located... We tested it after application of the lubricant but the minor clunking sound is persistently still there. He told me to purchase the bushings and he will install it afterwards since he suspect they are worn out and common for yaris.. Blessing in disguise, i went to the shops looking for the bushing and they were all closed for prayer time in KSA... I immediately went home and after lunch decided to have a car wash including the under chassis before going back to the mehanic. Ive instructed the guy to wash out the undercarriage properly then i saw some " sandy-materials sticking at the white lithium based grease" which was sprayed to the bushings... I specifically informed the car washing-guy to remove all the grease as i believe the bushing doesnt need to be greased.. Doing so, he removed all the sandy materials together with the sprayed lithium grease. Alas,after the car wash when i drive my car, it was completely very silent and no more clunking sound... In a desert area " sandy, dusty, dry weather" this led me to conclude that it was definitely the dust/sand and good thing i did not have to spend extra bucks replacing the good original bushings in my yaris... The high pressure water washer definitely did the job... :) Thank you. Last edited by rayfloyd170; 12-30-2018 at 04:14 AM. |
#4 | |
![]() ![]() Drives: 2007 Yaris hatch Join Date: Jun 2017
Yes, as of now after 1 week of removing that grease-sand from the ball-joint and bushings with high pressure water wash, my car is still very silent... I was hoping it will stay like this since my car is new at about 70K KM and i really took care of it... |
![]() Drives: 2009 Toyota Yaris Join Date: Oct 2016
Check this out. I am in Baja, Mexico. 2009 Yaris hatchback. I am reading this thread and I have already had 3 different indy mechanics inspect and none found any bushings, end links, tie rod end (whatever they are called) to be worn out.
It does not snow here. I have already replaced the upper strut mounts and recently the sway bar bushings as some mechanics suspected that may be the problem but unfortunately it was not. So I am going to replace the LCA bolt next. Ill report back. |
| Colour Collection 05 Reg (UK) brake noise | JLx | DIY / Maintenance / Service | 0 | 07-14-2015 06:56 AM |
| metallic noise when accelerating | poida | DIY / Maintenance / Service | 3 | 03-29-2015 12:20 AM |
| Yaris mk1 1.0 engine clunking noise | Gpav6 | Performance Modifications | 1 | 08-13-2014 01:42 PM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 12:27 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
