I am using my OEM yaris connector without an issue. The upstream one would have to be specific to the engine but not the downstream one. The downstream one is a "dumb" o2 sensor not like the upstream one which is a wideband sensor and controls afr's
Thanks Trevor. You say you're using the connector, you mean the whole Yaris o2 sensor, correct? I see Denso sells one that requires splicing. I think my problem is due to the wiring as it's very intermittent. If I can fix the wiring, I'll just use it, otherwise I'll just order one. Thankfully the downstream ones are a lot cheaper. I bought a real cheapie off ebay a while back for my '06 and had to put a defouler on it, but worked fine after that.
| 2003 Yaris 1.3 engine swap help | Jedi4690 | DIY / Maintenance / Service | 0 | 03-27-2018 03:08 PM |
| Yaris verso engine swap | Decieved | Performance Modifications | 3 | 06-10-2015 08:51 PM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
