Old 12-18-2018, 11:55 AM   #1
tmontague
tmontague's Avatar
Yes, I have the whole yaris part, sensor, wire and all.
What's the code being thrown, P0420?
Old 12-18-2018, 01:46 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Actually, I'm getting P0138 and P0607 (ECU) but from my reading that's not uncommon with the failing o2 sensor messing with the ecu. I'm going to remove the sensor, check the wiring and use a multimeter to check if the sensor is good. It was like $16.00 or something off ebay. The fault is very intermittent, I haven't seen it in 7 - 8 starts and runs, but it appeared a couple of days ago, again.
2003 Yaris 1.3 engine swap help Jedi4690 DIY / Maintenance / Service 0 03-27-2018 03:08 PM
Yaris verso engine swap Decieved Performance Modifications 3 06-10-2015 08:51 PM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
