Old 12-18-2018, 01:08 PM   #1
Mike Dexter
Drives: '10 Hatchback
Check for coolant in the oil. These codes can be the first indicator of a bad head gasket. Coolant in the oil impedes is ability to lubricate and can affect chain and cam position.
Mike Dexter is offline   Reply With Quote
Old 12-18-2018, 02:18 PM   #2
chefslot
Drives: xp90 1.3l 57
Thank you, no coolant in oil.
Changed oil and filter and the light has just come on again. Could it be a sensor/sensors and what should the resistance be on the sensors?
Regards
chefslot is offline   Reply With Quote
2006 Yaris (2NZ -FE 1.3) - P0010 bung206 DIY / Maintenance / Service 3 03-19-2018 02:33 AM
2006 Yaris (2NZ -FE 1.3 L) squeaking belt noise bung206 DIY / Maintenance / Service 1 06-21-2017 12:48 AM
