Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
The 138 code is due to a high signal voltage from the rear O2, it would be weird for that sensor to have an issue since it never gets touched during the swap. The connector is behind the dash and the wires pass through the fuse box back to the ECM.
The 607 is strange, could be due to water ingress or corrosion, or bad connections. I would start by looking at freeze frame data, then disconnect the battery. Then disconnect the engine harness plugs, inspect closely, then reconnect everything. |
#2 | |
| 2003 Yaris 1.3 engine swap help | Jedi4690 | DIY / Maintenance / Service | 0 | 03-27-2018 03:08 PM |
| Yaris verso engine swap | Decieved | Performance Modifications | 3 | 06-10-2015 08:51 PM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
