Old 12-21-2018, 10:43 PM   #1
Ah, all makes sense to me. I wasn't aware that the 2ZR could produce that power. The cams sound really promising. I did read that the 2ZZ has similar power output up to ~6500 RPM, then it comes on a lot stronger. Very informative stuff. Thanks.
My last vibe GT made 165whp with just an intake, fwiw.
But a 2zz/c60 won’t fit without cutting from rails, iirc.
I always thought the 2zr is the way to go in a Yaris..
Old 12-22-2018, 07:44 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That was the 2.4 in the GT, right? Oops, disregard. Not the 2.4.
Old 12-22-2018, 09:34 AM   #3
tmontague
tmontague's Avatar
That's not too shabby for just an intake. If someone was looking to compare bone stock engines and didn't mins the frame (and money wasnt as issue) then yes a 2zz would make the most sense. But when looking into aftermarket parts and running a standalone ecu I think the 2zr makes a lot more sense
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
