Old 12-22-2018, 10:43 AM   #1
Have you tested for a signal coming from the pressure switch?
Old 12-22-2018, 10:54 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I assumed, WeeYari, that since I was getting battery voltage at the compressor connector to trigger the clutch with the A/C switch on an illuminated that everything from an electrical standpoint was ok. With the connector removed, the A/C light will not illuminate. I'll dig deeper into this. Thanks!
Edit: The wiring at least looks the same. I guess I'll look into figuring out how to test that sensor.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
