#1 | |
No doubt your underdrive pulley is affecting that as you mentioned earlier. Practically every car I've owned drops cold air at idle and increased revs and more air through the condensor brings it back to life. Think I'll check out my other Yaris and minvan as well. Gotta make those gauges pay for themselves. LOL. How much does your A/C affect idle on the 2ZR? Mine seemed to labour slightly, until I removed a bit of the refrigerant. It still slows a few rpm when I engage A/C. I'm getting the impression that A/C systems are more power-robbing than I had initially thought.
#2 | |
I'd purge a bit of your r134 out but I dont think you need to release much
#3 | |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
