Old 12-23-2018, 08:09 AM   #1
atomic_hoji
Drives: 2018 Yaris SE 5MT
Woo! Nice - glad it's worked out for you. Good call by WeeYari.
-- Adam
atomic_hoji is offline   Reply With Quote
Old 12-23-2018, 09:03 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
-- Adam
Yes! I have a new theory, unsupported by EWDs or anything wiring related at this point: The last time I introduced R134, it was cold in the garage. As I mentioned the suction tube became heavily ice encrusted. Maybe the pressure sensor/switch froze up. Tapping it and letting it sit allowed it to open and become operational. So, I'm going with WeeYari's pressure sensor suggestion as being the problem.
Merry Christmas, gentlemen! And, as always, thank you for the invaluable help.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
