I used the above charts as well and they seemed to work well for me
I'm assuming they dont want you refilling in sub zero temps as it can lead to over charging the system if you are not aware of pressure changed in relation to ambient temps
#2 | |
| Tags |
| a/c, pressure |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| Help! A/C low pressure sensor..jumper? | marcus | Photo-Video-Media Gallery | 12 | 07-18-2012 05:50 PM |
| A/C intermittently cold | Wildcat | DIY / Maintenance / Service | 4 | 08-23-2010 03:21 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 04:46 PM |
