Your pressure sensor may be finding its place onto your shopping list. Mine failed in 2014. I lived without a/c until last year when I finally diagnosed my non-functioning a/c.
You are probably correct. They look fairly inexpensive, but would necessitate another discharge, vacuum and recharge. I think I'll do this in the spring/summer. I'll probably replace the schrader valves too as well as the o-ring at the firewall (expansion valve?).
Just ordered a Denso on eBay for ~$11.00. Do you happen to know, WeeYari, if the schrader valves are just standard R134 valves and if they are both the same size? Also, I think I'll need a special tool. I have one for tire schrader valves, but it may be different.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
