the whole xd rear drum assembly including the 5lug hub should fit. yaris and xd share the same axle beam. the xd drum is larger than the yaris.
3 Yaris and counting..
The xd drum wheel bearing/hub does bolt up to the Yaris axle. That's a fact. I did it myself. Only thing I don't know as of yet is if the ebrake cable and brake likne from the Yaris fit on the xd drum.
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 3rd gen engine swap, 2ZR? 2AR? Swap newbie | m.flores.0928 | Third Gen Yaris General Discussion | 6 | 10-02-2020 10:54 AM |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| 1zz swap...is it worth it??? | jouna | Performance Modifications | 12 | 11-10-2009 09:33 PM |
