Our local APM auto parts store actually had an A/C schrader valve tool - and this after calling half a dozen shops in the city 80 kms away and no one having one. $6.00 + tax out the door. I'm heading across the border tomorrow to pick up my Denso sensor, 2 cans R134 and the schrader kit.
Current plan is to wait for a warmish day, get my garage up to 65 - 70F, aim my big fan at the condensor and try again. I'll evacuate, replace the o-ring at the expansion valve, the schrader valves and pressure sensor. Then, a lengthy vacuum test. Finally a recharge quantity of R134 (~ 13 oz) and pressure tests based on ambient temps. From both what Trevor said and what I've read, this is work best not done in winter. I wonder if my vacuum tube would have iced up so badly in warmer weather.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 12-27-2018 at 10:49 PM. |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| A/C Clutch Compressor question | tmontague | DIY / Maintenance / Service | 3 | 05-11-2014 07:57 AM |
| A/C Broken On My 2010 5 DR HB | ChilliwackGuy | DIY / Maintenance / Service | 15 | 07-14-2010 04:33 PM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
