JDM Fan!
Drives: '06 Yaris Join Date: Sep 2018
Finally, I have success!!
The low beam stays on when I select the high beam ![]() I used a 6A 400V rectifier diode between the low and high beam ground wires connected to the low and high beam relays. So far the result is what I have been looking for Thank you all for your help along the way!!!
Regards, DeeBee |
#2 | |
JDM Fan!
![]() My HID's started flickering intermittently ![]() After some investigation I found that the harness I used had started melting connectors I had to disconnect everything and I'l have to do this install all over again in the summer! I think this time I'll look for one of the Morimoto harnesses that have been great in the past. Looking forward to bright headlights again....
Regards, DeeBee |
| FS: 2012 Yaris oem headlight projector retrofit | ucsmfu | Items for Sale by private party | 4 | 11-01-2016 10:28 PM |
| How can i get the OEM Headlight Stalk with FOG switch to work | murtaza.shahid | DIY / Maintenance / Service | 0 | 11-22-2014 06:30 AM |
| DIY - A EASY&FAST way to change headlight bulb | ALLBLACK | DIY / Maintenance / Service | 0 | 09-18-2010 01:40 AM |
| FS: Seibon, HID, JDM RS Tails, Shift Knob, Oddysey PC680 Battery, etc.. -- Socal | 03Z33 | Items for Sale by private party | 30 | 01-02-2009 06:55 PM |
| DIY - JDM RS style REPLICA tails | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-21-2008 02:56 PM |
