Old 01-06-2019, 04:33 PM   #1
tmontague
tmontague's Avatar
Subthetic oil tends to leak/burn more in an old engine as it is thinner at cold temps and flows better into small spaces even if viscosity is identical. If you want the synthetic oil for cold starts then go with a 0w40 instead of a 0w30. Based on your location I dint think your concern is cold start so just switch back to a conventional oil or go to a thicker viscosity
Old 01-21-2019, 02:49 PM   #2
ojeysky
Drives: Sedan Yaris 2010
Yeah I have no issue with cold start; lowest temperature here is 20C and that is occasional (it's usually above 30C), so what viscosity do you recommend I go for? By the way I was using 20w50 before but noticed performance improvement since I switched to synthetic 5w30 except that I loose oil. So what viscosity of conventional or synthetic should I switch to without loosing much performance and fuel economy?
ojeysky is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
